variables with type unsigned long problem
Dear All:
When I compile the the code with
the statement:
The type of short_idx is unsigned short.
Row1= (short_idx * 64) >> 8 >>8;
If the value of short_idx is 2048, the
Row1 should be 2,but Row1 will be 0.
But if I change the statement to the
following.
Row1= ((unsigned long)short_idx * (unsigned long)64) >> 8 >>8;
Then Row1 would become 2 and is correct.
So what should I do in compiler to avoid of such problem without adding "unsigned long" in every statement I used in my problem?
Thank you ...
  • You have assigned xbyte as unsigned char and trying to left shift it 8 times. This will cause an unexpected result.
    You try by type casting the xbyte to unsigned long as,
    X = (Unsigned long)XBYTE[XX] << 8;
    Always use the operations on the operands after keeping the data types in mind. - Neo
