pointer of pointer type??
what is different form, follow as:
(1)code XBYTE *AA[]={...};
(2)code void (*BB[])(void)={...};
  • "the coding above is not realizing."
    Sorry, what do you mean by that?
    Do you mean that it doesn't compile?
    If so, there's probably a fault in your definition of XBYTE.
    If you're using the standard Keil definition of XBYTE, then it will never compile - read the description of XBYTE in the C51 Manual.
