Hi Keil Users,
Good day.
I'm trying to read analog voltage from potentiometer and show the value in Keil. I tried to use adruino and it works.
Can anyone convert below arduino command to Keil? I'm using Nuvoton NUC131SD2AE and multi function shield.
Arduino Command:
#define Pot1 0 void setup() { Serial.begin(9600); } /* Main Program */ void loop() { Serial.print("P_reading: "); Serial.println(analogRead(Pot1)); /* Wait 0.5 seconds before reading again */ delay(500); }
Thank you.
github.com/.../main.c
