This forum may not be the best to ask the question, but the answers on the other forums (that i know) were generally with respect to C for desktop pc (where memory management is different from that in embedded) and this forum has knowledgeable embedded people. hence...
I was worried about the following situation:
void function1() { ... //other variables char* ptr = myary; ... ptr = ReadNandFlash("myfile"); ... } char* ReadNandFlash(char* Filename) { FILE* file; char temp_ary[256]; file = fopen(Filename, "r"); if(file == NULL) { return NULL; } while(!feof(file)) { fread(temp_ary, sizeof(char), 256, file); } fclose(file); return ary; }
will the 'temp_ary' be destroyed as only the pointer value is returned back to the function1()?
Not necessarily!
Remember that this is marked as a Non-Specific (Generic) topic. Not all compilers - notably, not all Keil compilers - use the stack for automatic variables...
What if we make the function1 a critical section, so that nothing can "interrupt" the function1. I guess it would always work safely?
Your code doesn't show where that myary buffer is.
And it has two assigns to the pointer but never seems to make use of the memory (myary) that the pointer points to.
Hi Andrew,
thank you for this clarification - I never ran across such a compiler.
Martin
myary is local to function1(). Sorry for that.
