JTAG Debug with external Memory
1. I would like to use the JTAG Port to Debug the XE167FH with the KEIL ULINK2.
2. There is no general problem of debugging the XE167FH with or without OS when I use JTAG Port A without additional external Memory, which would be connected with the EBC.
3. There is no general problem of debugging the XE167FH with or without OS when I use JTAG Port B without additional external Memory, which would be connected with the EBC.
4. There is no way to debug the XE167FH when using external memory, because the needed JTAG-Pins are blocked by the EBC!
In this Datasheet: "?
Or is there any other way to debug the XE167FH when using the EBC?
Thanks a lot
Markus Weber
