RTX Task Switching - JTAG ULINK2
I am running into something really unexplainable at the moment.
I have been developing my project code and testing it with Keil uVision 4.03 and ULINK2.
When I run the code using the JTAG connector and uVision I can see it is working fine. However, when I disconnect the ULINK2 connector and power cycle the board I can see that something has change. I can notice it right away because my GUI taak (low priority) runs slower. It also looks like it is doing this by a factor of 3.8.
What could be causing this?
Could it be that ULINK2 changes the RTX configuration?
I double checked SysTick timer and oscillators and their configuration is the same with and without the ULINK2.
