C51: Pointer to array type
I have defined a type for objects we use. The details of the type should not be relevant for the users of the type, so I am "hiding" it behind a typedef. As it happens, this type is currently implemented as an array.
This is problematic when we want to pass around pointers to variables of this type.
Example:
#define OBJECT_SIZE 5
typedef char   object_t[OBJECT_SIZE];  // A type that happens to be an array
int main( void )
  object_t     my_object;
  object_t   * p_object;
  p_object = my_object;      // Compiler warning - pointer to different objects
                             // (Correct warning - array decays to pointer to char. )
  p_object = &my_object;     // Compiler warning - pointer to different objects
                             // Why this warning?
                             // According to knowledgeable people, this should be
                             // OK with respect to the C spec
  return 0;
So, the question is: how can I obtain the address of the variable in a way that will give me a pointer to the given type? That is, I need a pointer to array[OBJECT_SIZE] of char, not a plain pointer to char.
With kind regards
Asbj.S.
  • The 'C' programming language has no such thing;
    That's quite completely wrong.
    Not only does the programming language have such a thing as "pointer to array"; it even works exactly the same as it would for every other "pointer to something".
    The thing that will not work for an array is assignment via that pointer, i.e. no
    *ptrToThing = *ptrToOtherThing
  • Not only does the programming language have such a thing as "pointer to array"; it even works exactly the same as it would for every other "pointer to something".
    That is my understanding too. But how do I get the pointer to the array?
    As seen from my original example (relevant part of it included below) C51 objects when I try to take the address of the array and assign it to a pointer to the type of the array, giving a warning about "pointers to different objects".
    With kind regards
    Asbj.S.
    int main( void )
      object_t     my_object;    // An object of the given type
      object_t   * p_object;     // And a pointer to an object of the same type
  • Try type casting. Let the compiler know exactly what you want to do...
    eg: p_object = (object_t*)(&my_object);
    -Dave
  • But how do I get the pointer to the array?
    The same way you would do it for any other variable: by using the '&' operator.
    I'm convinced the compiler is quite incorrect there.
    Although the language definition doesn't restrict what a compiler may emit diagnostic messages about, this one is pointless and factually wrong.
  • Try type casting.
    I would advise against that. Type casts of pointers are never the right solution, no matter what the problem seems to be.
  • I'm convinced the compiler is quite incorrect there.
    Actually, so am I now. I have read up on the spec (well not exactly, the K&R2 appendix). And while an array often is converted into a pointer to its base type, pointing to the first element of the array, this conversion does explicitely not take place when the array is the operand of the & operator. Which means that "&array" should give the correct result.
    I am discussing the issue with Keil.
    Asbj.S.
