Error C193 : '==' : illegal type conversion ??
I have tried to remove this error but no way.
Error C193 : '==' : illegal type conversion from/to 'void'
I have tried to include severals headers file but nothing, how can I resolve this error?
This error is in the function mem_task():
void mem_task (void)
Byte state;
  switch (mem_state)
    case MEM_INIT:
   #if MEM_CHIP_TYPE != CHIP_NONE /*if chip defined*/
     if (Hard_chip_init() == OK)/* if init chip OK*/
      mem_state = MEM_CHIP_INIT; /*install chip*/
   #if MEM_CARD_TYPE != CARD_NONE /*if card defined*/
    if (Hard_card_init() == KO) //ERROR: C193
      if (mem_state == MEM_INIT)/*if init fail*/
          print_screen(FATAL_CHIP_SCREEN);/*error*/
          while(1);
and my build target output is :
Build target 'Target 1'
compiling main.c...
compiling I2C.c...
compiling ADC.c...
compiling AUD.c...
compiling DAC.c...
compiling MICRO2.c...
compiling DONG2.c...
assembling STARTUP.A51...
compiling variable.c...
compiling ide_drv.c...
compiling C_Flash.c...
compiling CF_oper.c...
modules\file\fat.h(16): warning C322: unknown identifier
modules\file\fat.h(19): warning C322: unknown identifier
CF_oper.c(189): warning C307: macro 'fat_install': parameter count mismatch
CF_oper.c(240): warning C307: macro 'fat1216_save_cluster_info': parameter count mismatch
CF_oper.c(241): warning C307: macro 'fat1216_feob': parameter count mismatch
compiling cf_drv_.c...
compiling ata.c...
compiling file.c...
modules\file\file.c(184): warning C316: unterminated conditionals
compiling fs_variable.c...
compiling fat.c...
modules\file\fat.c(3790): warning C316: unterminated conditionals
compiling song_task.c...
compiling mem_task.c...
MODULES\MEM\MEM_TASK.C(123): error C193: '==': illegal type conversion from/to 'void'
Target not created
Thank you
  • About
    Illegal type conversion from 'void'.
    It seems like the function Hard_card_init() is of type void, i.e. it does not return any value. Hence, you don't have any return value to compare with. It might also be a result of all the wornings about unknown identifiers. Always fix your warnings/errors from the top.
    About
    Check if you have forgotten an include file, or included them in the wrong order. Or maybe the documentation says that you have to supply a couple of constants for your specific hardware.
