array index type of signed int
Hi list,
i'm working with c51v750a. My problem:
int array[ 0] _at_ 0x7600; //xdata
unsigned char index = 0; //xdata
printf("%d", &array[ index]);
printf("%d", &array[(unsigned char)(index - 1)]); //what is wrong?
// Result:
// 30208 --> 0x7600 (correct)
// 30206 --> 0x75FE == array[ -1] incorrect, // expected array[255] @ 0x77FE
I've read in Compiler's changelog [v7.50] that there was a fix for array with signed int index.
I don't need a workaround, but this seems like a compiler-bug. Or is my "logic" incorrect?
Thanks in advance,
Lars
  • I want to create a circular buffer with size of 256 (0-255)integers. The output is LIFO. In my case, the index-counter is decremented. The type of the index counter is unsigned char (0-255). There is no problem when i first decrement the index and then read/write the array. But when i put the result of the calculation (index - 1)
    array[(unsigned char)( index - 1)] //THIS IS AN EXAMPLE
    the result of the index-counter is -1, for index = 0. The result without typecast is correct ( -1, int), but when i put a typecast before, it has to be 255!! I know how to avoid this problem, but in my opinion this is a bug in the compiler.
  • "The output is LIFO."
    Surely, that's a stack - not a circular buffer?
  • "Surely, that's a stack - not a circular buffer?"
    It's a mixture of both, but please, don't misinterprete the use of this code. To get the problem, you don't need to know what is the use of the code. I don't want to discuss about storage technics.
  • There's definitely something odd going on here. Take a look at this:
       int xdata array[256] _at_ 0x7600; //xdata
       unsigned char idx;
       idx=(unsigned char)(index - 1);
       printf("%p\n", &array[(unsigned char)(index - 1)]); //x:75FE
       printf("%p\n", &array[idx]); //x:75FE
       printf("%p\n", array+(unsigned char)(index - 1)); //x:77FE
       printf("%p\n", array+idx);   //x:75FE
  • Sorry, ingore my previous post. It's full of typos. This is hopefully correct:
       unsigned char idx;
       printf("%p\n", &array[idx]); //x:77FE
       printf("%p\n", array+(unsigned char)(index - 1)); //x:75FE
       printf("%p\n", array+idx);   //x:77FE
  • Stefan,
    did you compile with c51v750a ? BTW, the software-versions which are displayed in the uV2 are:
    C-Compiler C51.exe v7.50
    Assembler A51.exe v7.10
    Linker BL51.exe v5.12
    Librarian LIB51.exe v4.24
    I'm sure i've updated to C51v750a.
    I will compile the example code with an older version and post the result here.
  • "did you compile with c51v750a ?"
    No, C51 v7.01.
  • "No, C51 v7.01."
    ok, then i don't need test it with my older version V7.04
    I will contact Keil for informations, thanks.
  • "I will contact Keil for informations, thanks."
    Please post the result when you get one.
  • Today i received a mail from Keil:
    Mr. Schneebauer wrote:
    "prinzipiell haben Sie Recht, daß es sich hier um einen Fehler handelt.
    Normalerweise versucht der Compiler das '-1' in die Konstanten zu
    verpacken um das Programm besser zu optimieren. Wir haben diesen Fehler
    nun auch behoben. Da Änderungen an zentralen Funktionen gemacht wurden,
    muß dieser Compiler noch ausführlich getestet werden bevor wir ihn
    ausliefern können."
    Basicly, what he writes is:
    Yes, its a bug. The bug is fixed and the new compiler-version will be tested.
    Stefan, thank you for verifying this problem.
