floating point datatype
Hello
Can any body tell me how to use floating point datatype for programming in C in kiel.
i have defined in the following way
float i= 19.5;
or
float j= 18.2/255;
but these are given as errors.
please tell me how to use floating point datatype for Keil.
Thanking you
  • yeah i am using evaluation software.
    but i am confused to see this
    here
    unsigned char j=0xb6;
    and if i write
    unsigned char k = 255*(1- (float)18/0xb6)
    i am not getting any error and the result is same as what i wanted.
    but if i use it in the following way , i am getting error.
    unsigned char k= 255*(1-(float)18/j)
    where j=0xb6.
    Is there no other way to perform division operations in evaluation version
    -Pradeep
    here
    and if i write
    where j=0xb6.
    -Pradeep
  • The right hand side of this line only contains constants:
    so the compiler evaluates it for you.
    This line has a variable on the right hand side:
    so it has to be evaluated at runtime, which you can't do with the evaluation version.
