Concerning CAN objects that can have multiple filters assigned...
The following CMSIS structure tells the application about the filtering capabilities of each object. It is returned in the ARM_CAN_ObjectGetCapabilities() call. Is the "multiple_filters" element a ONE/ZERO to indicate this capability or is it numeric that says how many filters can be assigned. If the former, how do I tell how many?
typedef struct _SPI_CAN_Obj_Capabilities { uint32_t tx : 1; /* Object supports transmission */ uint32_t rx : 1; /* Object supports reception */ uint32_t rx_rtr_tx_data : 1; /* RTR reception auto data transfer */ uint32_t tx_rtr_rx_data : 1; /* RTR transmission auto data reception */ uint32_t multiple_filters : 1; /* Object allows assignment of multiple filters to it */ uint32_t exact_filtering : 1; /* Object supports exact identifier filtering */ uint32_t range_filtering : 1; /* Object supports range identifier filtering */ uint32_t mask_filtering : 1; /* Object supports mask identifier filtering */ uint32_t message_depth : 1; /* Number of messages buffers (FIFO) for that object */ }SPI_CAN_Obj_Capabilities;
I previewed and edited this post so the structure would appear readable, but unfortunately it still died in the posting...
That's likely due to you not reading/digesting the posting instructions. You need to embed code in between <pre> and </pre> tags.
Yup, my bad... I saw the bold and Italics stuff and tuned out the rest.
