Hello I'm working on stm32f10x but some times it hangs or jumps to unknown location or I missed my Ethernet connection abruptly. I want to know how can do full debug with keil and JTAG (I use J-link programmer and debugger)? for example I need to know 1)which function and line was the last function or line before MCu got hang? 2)how can debug network interface socket?(I have read www.keil.com/.../network_create_app.html but I can't understand how to debug)
1) If Cortex-M is faulting, then you can use Application Note 209: http://www.keil.com/appnotes/files/apnt209.pdf to find the line or at least the area (within a few lines) where the fault occurs. The call stack & locals window can also be helpful, here.
2) Go to Manage RTE window => Compiler => IO. The project stills need to retarget printf to get network debugging messages (these use a form of printf, for now). There is documentation on multiple ways to direct this output in the side link "Retarget Input/Output". I recommend using ITM, but this requires JLINK to perform a trace. The documentation for trace setup is here: http://www.keil.com/support/man/docs/jlink/jlink_stm32f10xxx.htm
