Hi, When I using ULINK2 to program LPC2478, the uVision4 showed "no JTAG device found". It was working normal before but failed suddenly at this board. Can anyone help me on this ?
May be the code you programmed on the device is interfering with the JTAG pins/configuration.
Erase the device of your code, use an alternate ISP method, or boot mode, if the device permits such.
If it's an electrical issue, either with the power, connection, oscillators, etc you'll need to break out some equipment and test/diagnose the underlying issue.
Thanks Westonsupermare Pier, Actually I have several boards and now the ulink2 can not detect all of them. I got another good ulink2 and it worked without any issue. I confirmed it is ulink2 problem but i'm really concerning what make it fail. :(
