Where does RL-RTX store function return addresses?
Hi Everyone.
I am a little confused about something.
Let's Suppose I'm running some concurrent tasks in RL-RTX. and let's say one of those tasks is calling a chain of functions ( a function that calls a function that calls another function).
I have 2 questions:
1. Where are the return addresses stored before jumping to the function instruction? Is it stored on the task's stack?
2. if it is stored on the task's stack, then is this (size of the return addresses) taken into account when the linker calculates "Maximum stack depth" and "Stack usage" stored in the html file in the output directory? or is that only the automatic variables?
Thank you very much in advance.
  • ===A.==================================================================
    www.keil.com/.../armlinkref_CHDGDFFF.htm
    The static callgraph also gives information about stack usage. It lists the:
    size of the stack frame used by each function
    maximum size of the stack used by the function over any call sequence, that is, over any acyclic chain of function calls.
    http://www.keil.com/support/man/docs/armcc/armcc_CJAIIDCG.htm
    C and C++ both use the stack intensively to hold, for example:
    the return address of functions
    registers that must be preserved, as determined by the ARM Architecture Procedure Call Standard (AAPCS)
    local variables, including local arrays, structures, unions, and in C++, classes.
    ===B.==================================================================
    http://www.keil.com/support/man/docs/rlarm/rlarm_ar_stack_man.htm
    The Stack Management of the RTX kernel is designed for optimal memory usage. The RTX kernel system needs one stack space for the task that is currently in the RUNNING state:
    Local Stack: stores parameters, automatic variables, and function return addresses. On the ARM device, this stack can be anywhere. However, for performance reasons, it is better to use the on-chip RAM for the local stack.
    http://www.keil.com/support/man/docs/rlarm/rlarm_ar_cfgstack.htm
    On the full context task switch, the RTX kernel stores all ARM registers on the stack. Full task context storing requires 64 bytes of stack.
  • There are several different types of stacks.
    1. the default system mode stack (which is defined in the startup file)
    2. the default user mode stack (which is defined in the startup file)
    3. the default user/system mode stack for interrupt service routines
    4. The RTX kernel system needs one stack space for the task that is currently in the RUNNING state
    5. The RTX kernel system needs one stack space for the os_idle_demon
    6. The RTX kernel system needs several stack space for the tasks
    I guess that,
    the context save of a task / an interrupt service routine is not counted by Linker
    the hidden stack usage of RTX kernel system is not counted by Linker
  • I already verified that the context save is not included in the maximum depth calculated by the linker.
    Thank you for your reply.
