Hi, I'm just curios on how this work. Is this a general C/C++ process or C51?
In main.h, I have a:
#define MAX_TIME_OUT 3000 //This is beyond U8
In Worker.c, I have Timer 2 ISR:
#include "main.h" U8 _temp_cntr; //unsigned char and not initialized //T2 init here void T2_ISR() interrupt using 0 { //some flag being set here _temp_cntr++; //Should this be back to 0 when reach 255? if(_temp_cntr == MAX_TIME_OUT) //What will happen here? { _temp_cntr = 0; } }
Hope somebody can enlighten me on this. My UART1 on F387 mcu won't able to run when Timer 2 ISR is enabled because of the specific condition under the ISR.
thanks gp
If code below is missing, it would cause timer 2 interrupts non-stop affecting system operation: TF2 = 0;
Also, it could be a good idea to declare the variable as volatile if it is also accessed in the main program.
