Ulink jtag problem,
I am using STR9. While trying load the program to the flash memory, I get the following error,
In debug: "memory mismatch address 0x00000 value: 0xff extected 0x18"
while downloading: "flash download failed could not stop ARM9E device please check the JTAG cable"
Ramazan ARIKAN
  • Yes I verified the algorithm. The microcontroller is STR912FAWX6, and the algarithm is "ULINK arm debugger". However, automatic device chain initilization is failed. I manuelly add the device. If I choose auto detection, it it says that "JTAG connection failed".
    When I press the load button, the device is resetted. But I get the massage "flash download failed could not stop ARM9E device please check the JTAG cable"
    best regards
    Ramazan
    best regards
    Ramazan
