I am trying to use RTL for the tcp communication part on the lpc2368 project. The stack ran ok on the lpc2378, but on 2368 it appears that the function Init_Tcpnet() somehow disables a jtag. After this function is executed, jtag doesn't connect anymore, giving an error "can't stop arm device". The only way to restore connection is to erase a chip with Flashmagic. If I insert a loop before Init_Tcpnet(), connection never fails. Pins and functions for ethernet are exactly the same for 2378 and 2368, so the reason is not in pin configuration, but somwhere else. Did anybody have a similar problem?
Gennady
I've put a delay of 2S at the beginning of main(). Now behaviour is a little bit different. Debug session always starts, and if Init_Tcpnet() is not there, everything is ok. If Init_Tcpnet() is present, any attempt to stop a processor leads to the following: - message "Could not stop ARM device!" appears. - on 'OK' 'Stop' icon greys out and 'Run' icon appears. - attempt to run leads to dropping out of the debug session.
There are 2 things I can think about: 1. hardware - PHY initialization. I beleive that Init_Tcpnet() includes PHY initialization, so possible hardware problems probably can lead to the above behavior. 2. I am using ULINK jtag, not ULINK2. Fmax is 200KHz (I also tried 100KHz). Are there any issues with ULINK that can lead to the problem?
Yes, it was a hardware problem. PHY oscillator was connected incorrectly and gave non-standard clock (and consequently no clock to the processor from PHY). Absence of this clock somehow affected jtag connection. Anyway, I am glad it's resolved now.
Thank you for the response.
