Code (Salvo) compiles fine under Cx51, but results in a WARNING L25: DATA TYPES DIFFERENT message when compiled under C-ARM. This only affects pointers (they're all pointers to structs), where they're declared in one module (mem.c) and accessed in another (init.c) via extern declarations. Compile options on both files are the same, no other issues. I've seen (and resolved) this sort of problem before in Cx51 when there was a mismatch between a source file and a library I had generated. In this case, there's just two source files involved, so I'm a bit stumped. Can anyone help? Thanks,
Here's another oddity .. even though the pointers are defined in mem.c, and accessed via extern declarations from other files (e.g. init.c), the .map file lists each pointer as MODULE: mem.obj and DEFINED: init.obj. I hope that this doesn't mean that LA thinks these objects are defined in init.obj ...
More info ... Adding a second file (sched.c) to the project that also acceses the pointers via external declarations causes LA to crash (100% consistent), yet uVision3 survives, and the build result is a build with 0 errors and 0 warnings ... Methinks this is a toolset bug ...
