3.3V IO Output Voltage needed (MCXBX167)
I'm using the XC167 Controller and i want to send
signals via the IO Port3 (i.e. P3.0) to addintional
hardware. the output level of the controller is
4-4.55V in high level. But my hardware allows only
2.0V - 3.5V. How can i do so?
I've read in the Datasheet that it is possible
to switch the output driver to an open drain configuration
and use a external pullup resistor.
Does anyone has experience in that? Cause i don't want
to destroy some hardware only because of too
high voltage.
Regards
Marco
  • As the datasheet says, use pull-up resistors to 3.5V or 2V (whatever is available) and use the output port in open drain mode.
    Things to watch out for: as always with pull-up resistors and open-drain outputs, there is a trade-off between speed and power consumption. Higher pull-up resistance means slower rise time and lower resistance means higher current through the resistor in the "output low" state. Rise time is roughly R*C, where R is the pull-up resistance and C is the stray capacitance of the conductor. You also have to make sure that the output port current rating of the microcontroller is not exceeded, which puts a limit on the lowest resistance that can re used as pull-up. Take into account output resistance of the port, which can be significant with low pull-up resistance.
    - mike
    - mike
