converting types
hi Forum,
how can i convert items in a Array from typ Char[] in an Integer-Type?
example:
char data[] = "110111";
int sum = 0;
sum = (int)data;
or should i sum the all items in the array bitwise?
  • You seem to have a fundamental misunderstanding about what an array is.
    In 'C', an array's name gives the address of the 1st element of the array - it is effectively a pointer to the start of the array.
    sum = (int)data;
    attempts to take the pointer value, and put it into an int variable.
    This has absolutely nothing whatsoever to do with the values of the elements of the array!
    If you want to find the sum of all the elements in an array, you will have to add them all up:
    sum = array[0] + array[1] + array[2] etc, etc,...
    Of course, in real life, you'd probably use a loop to do this.
    An array definition like
    char array[] = "110111";
    initialises the elements as:
    array[0] = '1'
    array[1] = '1'
    array[2] = '0'
    array[3] = '1'
    array[4] = '1'
    array[5] = '1'
    array[6] = 0x00
    Note the 1st six elements contain the characters '0' and '1' (ASCII code values 0x30 and 0x31) - they do not have numerical values zero and one.
    Note also that data is a reserved keyword in C51.
    sum = (int)data;
    array[0] = '1'
    array[1] = '1'
    array[2] = '0'
    array[3] = '1'
    array[4] = '1'
    array[5] = '1'
    array[6] = 0x00
