HOW TO MERGE THIS TYPE OF DATA INTO FILE
HI
all
iam working cygnal microcontrollers .From the console iam sending text file to the controller through uart transmission.The data in the text file is written into controller external memory.
lets take an example
the text file contains the below data
1111111111111111ffffffffff
now i want to add 0203 to the above data
that means i have to get in this format
020311111111111111110203ffffffffff0203
that means after every 8 bytes i have to
add 0203 in the text file
the 0203 values the user will enter as message overheads
kindly provide me how to implement this
regards
john e
  • "the text file contains the below data 1111111111111111ffffffffff now i want to add 0203 to the above data"
    "I'd assumed he wanted the Cygnal to do it..."
    Yep, that's the problem with ambiguous requirements. I had focused on file, when you had an entirely different interpretation. Either way, it shouldn't be a big deal to do.
