To the best of my knowledge the 'if' below should test 2 bytes. What is wrong here
void funct(unsigned char *valptr) { if (((unsigned int)*valptr) != 0) generates 0012 8F82 MOV DPL,R7 0014 8E83 MOV DPH,R6 0016 E0 MOVX A,@DPTR 0017 60F9 JZ ?C0047
*valptr = (unsigned long) 0 ;
In other words, here is the code to sort out the thing:
void funct(unsigned char *valptr) { if ((*(unsigned int*)valptr) != 0) // ...
Thanks Mike, I'm up and running. Erik PS: should the failed attempts not have generated an error or at least a warning.
"should the failed attempts not have generated an error or at least a warning." As I've noted before, this is both the strength and the danger of pointers in 'C'! With pointers, the ethos of the 'C' language is very much, "you asked for it; you got it!" This is particularly true of embedded cross compilers, which tend to be relatively light on the amount & detail of their diagnostics. This is where tools like lint come in. Passing your code through a "big" compiler (eg, MSVC, Borland) will often elicit more detailed diagnostics.
