onversion 8/16 bit types problem
Hi!
I've the following problem!
I receive via CAN a 16-Bit value, I'll use for some calculations on a
Siemens C167CR, und transmit the result again back via CAN!
The following code works fine on a PC:
(test 16 ist declared as an unsigned int, the byte_high and byte_low
as char)
test16 = byte_high;
test16 = test16 << 8;
test16 = test16 | byte_low;
The way back:
byte_low = test16;
byte_high = (test16 >> 8);
also works fine (on the PC)!
But the code doesn't work on the C167!
It seem's, that the C167 doesn't make the conversion back not correct.
Thanks for your tips!
SVEN
