For the 1×1 input 3+4i, ArmPL’s LAPACKE_zgeqrf returns success but leaves R=3+4i and tau=0. This is a valid QR factorization, but it differs from reference LAPACK’s real-diagonal convention. Is this difference intentional? It affects downstream code, including PyTorch’s complex QR derivative (`torch.linalg.qr` forward gradients disagree with finite differences for complex128 on Windows ARM64 with ArmPL · Issue #206869 · pytorch/pytorch), that relies on that convention.
3+4i
LAPACKE_zgeqrf
R=3+4i
tau=0
Minimal repro using native ARM64 Python and the official Windows installer DLL; no NumPy or PyTorch required:
import ctypes as c lib = c.CDLL(r"C:\Program Files\Arm Performance Libraries\armpl_26.07\bin\armpl_lp64.dll") z = c.c_double * 2 # One complex double: real and imaginary parts. a, tau = z(3, 4), z() info = lib.LAPACKE_zgeqrf(102, 1, 1, a, 1, tau) print(info, complex(*a), complex(*tau))
Observed: 0 (3+4j) 0j
0 (3+4j) 0j
Reference behavior: R=-5+0j, tau=1.6+0.8j. ArmPL’s own zlarfg_ returns those values when called directly on the same scalar. The question is not whether R should be positive or negative, but whether its diagonal should be real.
R=-5+0j
tau=1.6+0.8j
zlarfg_
R
github.com/.../zgeqrf.f
