armflang #include does not work with absolute path
This issue was initially brought to my attention at https://github.com/open-mpi/ompi/issues/11737
With armflang 22.x and the latest 23.04.1, the #include directive does not work as expected.
Instead of opening the file with an absolute path, it tries to append the absolute path to the include directories.
Here is a simple way to evidence the issue:
$ armflang --version
Arm C/C++/Fortran Compiler version 23.04.1 (build number 14) (based on LLVM 16.0.2)
Target: aarch64-unknown-linux-gnu
Thread model: posix
InstalledDir: /opt/arm/arm-linux-compiler-23.04.1_RHEL-8/bin
 more /tmp/include/header.h /tmp/src/main.F90
! dummy header
/tmp/src/main.F90
#include "/tmp/include/header.h"
armflang -c main.F90
F90-F-0906-Can't find include file /tmp/include/header.h (main.F90: 1)
F90/aarch64 Linux FlangArm F90  - 1.5 2017-05-01: compilation aborted
FWIW, using a relative path works as expected
$ more main2.F90
#include "../include/header.h"
program main
end program
$ armflang -c main2.F90
I suspect this is a bug, but if this is a feature/limitation of armflang, please let me know.
FWIW, I tried flang-new from LLVM 15 and 16 but the error does not occur with these compilers.
