How to update the trusted firmware for Juno board?
Hi experts ,
I have a Juno r1 board and I'm using it as the instruction of this page's "Building from source" section.
Now I want to update some secure related registers (e.g., SCR_EL3) for my board. These update operations require EL3 privilege.
In this case, I think I need to write the code in secure monitor layer. I hope I can update the register value while booting time so I think I should add code in the BL2 or BL31 according to the Linaro slides page8.
My workspace contains the folder arm-tf which looks like the part I should work with.
However, after running script build-arm-tf.sh, I do get the bl2.bin and bl31.bin while I don't know how to push these files into my board and use them for trusted booting.
So my questions are:
1. To update the register with EL3 privilege, should I add code in trusted firmware layer?
2. Can I update the trusted firmware by myself for Juno r1? If I can, how?
If I misunderstand any part, please let me know.
Thank you in advance.
Shengye
  • Hi,
    Yes. Probably in AP_BL1 or AP_BL31, but exactly where in TF depends what you are trying to do.
    I assume you mean - how do you "apply" the rebuilt binaries to the board? If so. This is covered in the instructions
    https://community.arm.com/dev-platforms/b/documents/posts/using-linaros-deliverables-on-juno 5.2 Built from source section.
    Basically you copy the binaries to the MMC card and these are written to flash on boot.
    HTH
    MarkN.
  • Hi Mark,
    Thank you for the reply. Your post did help me rebuild the firmware bin file.
    However, now I met a new problem.
    Currently I'm trying to write several system control registers with EL3 privilege such as SCR_EL3.
    I put my code in the trusted firmware boot loader (BL31).
    Here is my code that I put in the bl31_main of arm-trusted-firmware-source-code:
    asm("MRS    %x[result], SCR_EL3"
        : [result] "=r" (scr)
    asm("MSR    SCR_EL3, %x[value]"
        : [value] "r"   (scr)
    I can read the value of the register correctly and I checked the register CurrentEL which says I did have the EL3 privilege.
    However, every time after I write new value to SCR_EL3, its value doesn't change.
    I also tried several other registers (some registers only requires EL1 privilege while I can't write anyone successfully with the instruction MSR).
    Now I cannot come up with what might cause this problem. Do you have any idea or suggestion for my problem?
    Thank you in advanced.
    Simon
  • AT BL3-1 I don't see any immediate reason why you can't modify these registers because of privilege.
    Do you have a debugger (e.g. DS-5/DSTREAM) so you can step through this one instruction and a time and check the status of these system register updates?
    GUESSES, but...
    - Are you using the right access size for the register (check the ARM ARM)?
    - Could the update be successful, but changes are overwritten again elsewhere in the firmware? You could try putting some instrumentation/printfs in the code to see if you can learn more.
