NIC-400 QVN: W data output gap differs (0/2/1 cycles) across token_prerequest settings
Hi all,
I'm seeing different write data throughput behavior on NIC-400 (r1p2) with QVN-400, and would like to ask if anyone can help explain.
## Setup
- **NIC-400 r1p2** with QVN-400
- Path: CPU (ASIB) → Switch → DDR (AMIB)
- CPU sends write transactions(len=0) **back-to-back** (0-cycle gap between transactions)
- Three configurations tested:
| Config | QVN        | token_prerequest | DDR W output gap             |
| 1         | Disabled | false                      | **0 cycles** (back-to-back) |
| 2         | Enabled  | false                      | **2 cycles**                         |
| 3         | Enabled  | true                       | **1 cycle**                           |
## Key question
Why does `token_prerequest=false` produce a 2-cycle gap, `token_prerequest=true` produces 1-cycle, and no-QVN produces 0-cycle?
## My understanding
- **No QVN**: Data flows one-directionally with no feedback path — pipeline latency doesn't affect throughput, gap = 0.
- **QVN + prereq=false**: Each W beat needs a full token request→grant→return round-trip, gap = 2.
- **QVN + prereq=true**: Token is pre-allocated, eliminating the request round-trip, but W channel doesn't support pre-allocated tokens (only AR/AW do), leaving 1 cycle, gap = 1.
## Questions
1. Is there any other source of W-channel gap in QVN mode besides the token round-trip? (e.g., internal arbitration, VN switching)
2. The W-channel pre-allocated token limitation (AR/AW only, not W) — is this documented in the TRM? I found it in the ARM Community QVN introduction but not in DSU0027H.
3. Any recommendations on how to reduce the W data gap to 0 while keeping QVN enabled?
Any insights appreciated. Thanks!
