Unable to run neoverse stack on RDN2 platform
Followed the steps mentioned in this learning series - Test With FVP | Arm Learning Paths to test neoverse reference stack on RDN2 platform. Built the image and tried running on RDN2 FVP but getting below error
Error: license log: Failed checkout of FM_ARM_PUBLIC for the license feature SG_ARM_Cortex-M7_CT
In file: /tmp/plgbuild/abs_build/1371436_71421/trunk/work/fastsim/Framework/Engine/SCXSimulationEngine.cpp:3025
Error: license error: Simulation Engine module unavailable!
In file: /tmp/plgbuild/abs_build/1371436_71421/trunk/work/fastsim/Framework/Engine/SCXSimulationEngine.cpp:2652
ERROR: uncaught exception occurred. Exception message follows:
Error: Wrong version of armctmodel. Version 11.25.23 (API Version 1.2) of the Portfolio was used to build the model. Please use identical major.minor versions of the Portfolio and the Tools.
I've tried the same for RDV3R1 but did not see any issue in running the stack. I want to use RDN2 platform but facing above error. Kindly let know how to resolve this issue.
  • Hello,
    You likely have other (commercial) Fast Model products in your path that are conflicting with the Ecosystem FVP, which does not use any license.
    Try unsetting PVLIB_HOME environment variable, if defined.
    Regards
    Ronan
  • Hi Ronan,
    Thanks for the reply. Yes, I had Keil Free edition license that was causing this problem. After removing this license I dont see issue with running RDN2 FVP.
    Since it allowed to run RDV3R1 FVP, there was confusion.
    Thanks.
    Regards,
    Shivakumar
