DAP600 - SWD -> JTAG Mode Switch Issue
We are seeing an asymmetric SWJ‑DP mode‑switching issue on the SoC:
  • Working: JTAG → SWD (IDCODE and register accesses pass).
  • Failing: SWD → JTAG. The device does not enter Dormant, so JTAG IDCODE and subsequent register accesses fail.
For reference, at IP level this switching works. The IP uses dap_dp_switchmode() whereas the SoC flow uses dap_dp_switchmode1(), which dynamically adapts to the SoC component tree/ROM‑table rather than a fixed pointer. Function definitions are in the attached document.
Test sequence (SoC):
Failing sequence (SWD → JTAG):
  1. Start in JTAG default mode.
  2. Switch to SWD and perform register accesses → PASS.
  3. Switch back to JTAG → IDCODE read fails and register accesses fail.
  4. Switch back to SWD → IDCODE/register checks PASS.
Passing sequence(JTAG -> SWD):
  1. Start in JTAG and perform accesses → PASS.
  2. Switch to SWD → IDCODE/register PASS.
  3. Switch back to JTAG → IDCODE/register PASS.
Core/IP Passing Sequence:
  1. After Reset(nTRST), We are in JTAG mode
    2. Switching from JTAG to SWD mode without any transactions
    3. Accessing Scratchpad register with data 5A5A5A5A(both write and read)
    4. Sending a Handshake to TB by writing fffffff1 from C test and reading same value in TB
    5. After reading fffffff1 going to CX min scenario.
    6. doing Dummy write
    7. Waiting for 10000 SWCLK cycles
    8. Switching from SWD mode TO JTAG mode and reading the idcode.
uint32_t dap_dp_switchmode(void)
   uint32_t     sw_dpidr    = 0;
   uint32_t     jtag_idcode = 0;
   if(init_data.default_route_index == 0)
      MSG("[CXDT MSG] dap_dp_switchmode: Switching route to access the DP using Serial Wire:\n");
      init_data.default_route_index = 1;
      if(SelectMemRoute(&mydp->addr, 0, route_p, MAX_ROUTESTEPS) == 0)
        return FAIL;
      if(ReadReg(DP_DPIDR, &sw_dpidr, route_p) == FAIL)
        return FAIL;
      MSG("[CXDT MSG] dap_dp_switchmode: Read  SW_DPIDR: 0x%08x", sw_dpidr);
      // Check for expected value
      if(sw_dpidr == EXPECTED_SW_DPIDR)
        MSG("\n");
        return PASS;
      else
        MSG_ERROR("Expected SW DPIDR: 0x%08x\n", EXPECTED_SW_DPIDR);
        return FAIL;
   if(init_data.default_route_index == 1)
      MSG("[CXDT MSG] dap_dp_switchmode: Switching route to access the DP using JTAG:\n");
      init_data.default_route_index = 0;
        return FAIL;
      if(ReadReg(JTAG_IDCODE, &jtag_idcode, route_p) == FAIL)
        return FAIL;
      MSG("[CXDT MSG] dap_dp_switchmode: Read JTAG IDCODE: 0x%08x", jtag_idcode);
      if(jtag_idcode == EXPECTED_JTAG_IDCODE)
          MSG("\n");
          return PASS;
      else
          MSG("Expected JTAG IDCODE: 0x%08x\n", EXPECTED_JTAG_IDCODE);
          return FAIL;
uint32_t dap_dp_switchmode1(void)
   if(SOC_DATA.default_route_index == 0)
      MSG("[CXDT MSG] dap_dp_switchmode1: Switching route to access the DP using Serial Wire:\n");
      SOC_DATA.default_route_index = 1;
       for(uint32_t instindex = 0; instindex < *socdata_p->num_components_p; instindex++)
        csinst_t * inst_p = &socdata_p->components_p[instindex];
            if(inst_p->type == DEBUGPORT)
                MSG("\nCXDT MSG:Checking Debug Port: inst[%u] (%s)\n", instindex, inst_p->name);
                if(SelectMemRoute(&inst_p->addr, 0, route_p, MAX_ROUTESTEPS) == 0)
                    MSG_ERROR("TUBE:Could not access DP.\n");
                    return FAIL;
        return FAIL;
      MSG("[CXDT MSG] dap_dp_switchmode1: Read  SW_DPIDR: 0x%08x", sw_dpidr);
        MSG("\n");
        return PASS;
      else
        return FAIL;
   if(SOC_DATA.default_route_index == 1)
      MSG("[CXDT MSG] dap_dp_switchmode1: Switching route to access the DP using JTAG:\n");
      SOC_DATA.default_route_index = 0;
                    return FAIL;
        return FAIL;
      MSG("[CXDT MSG] dap_dp_switchmode1: Read JTAG IDCODE: 0x%08x", jtag_idcode);
          MSG("\n");
          return PASS;
      else
          return FAIL;
  • Please raise an official support case from the menu below.
    I do not think this level of question can be addressed in a public forum.
  • I tried sending an email to the suggested ARM support mail address "support@arm.com", but it seems that the process to raise a support ticket has changed. I registered and created an ARM account, but I’m unable to open a support case. Whenever I attempt to raise a ticket, it redirects me to an AI based answer assistant. I was unable to open a support case so posted query on public forum. Will you pls help on the steps to open a support case? Thanks in anticipation!!
  • If the suggested AI response does not answer your query there should be a button saying (something like) "Continue to open case".
    Have you used a free email account (gmail or similar?). Those may be blocked.
