Issue of Building the OpenEmbedded Filesysytem from Source for Juno
Hi , ,
I'm currently using a Juno r1 board and I'm running the Linaro's deliverables on my board.
Recently I want to build the OpenEmbedded system by myself so I checked the instruction. However, after I finished the first 8 steps
$ mkdir openembedded
$ cd openembedded
$ export OE_HOME=`pwd`
$ git clone git://git.linaro.org/openembedded/jenkins-setup.git
$ cd $OE_HOME/jenkins-setup
$ git checkout release-YY.MM
$ cd $OE_HOME
$ sudo jenkins-setup/pre-build-root-install-dependencies.sh
I met errors for the command "$ jenkins-setup/init-and-build.sh"
simonwan@I-Love-Research:~/oe_build$ jenkins-setup/init-and-build.sh
GCC version: 4.9
Target architecture: armv8
Manifest branch: master
Manifest URL: git://git.linaro.org/openembedded/manifest.git
Manifest groups:
Init env:
Verbose:
Local download directory:
Enable ptest: 0
real	0m0.002s
user	0m0.000s
sys	0m0.000s
jenkins-setup/functions.sh: line 337: cd: poky: No such file or directory
jenkins-setup/functions.sh: line 340: ./oe-init-build-env: No such file or directory
jenkins-setup/functions.sh: line 69: conf/bblayers.conf: No such file or directory
realpath: /home/simonwan/oe_build/../openembedded-core/meta: No such file or directory
jenkins-setup/functions.sh: line 106: conf/bblayers.conf: No such file or directory
jenkins-setup/functions.sh: line 120: conf/site.conf: No such file or directory
jenkins-setup/functions.sh: line 192: conf/site.conf: No such file or directory
sed: can't read conf/local.conf: No such file or directory
jenkins-setup/functions.sh: line 278: conf/local.conf: No such file or directory
jenkins-setup/init-and-build.sh: line 107: bitbake: command not found
Is there anything I missed for initiate the workspace?
Thank you.
Simon
  • Simon,
    As per Ash's post you wouldn't generally need to build OE from source. But, I had a look at the problem you report...
    I believe your issue is caused by not having a valid repo tool on the PATH. This causes the OE script function git_clone_update() to silently fail, which means you'll have no openembedded-core directory.
    I've just added a new line to community.arm.com/.../using-linaros-deliverables-on-juno Section B.1 about installing repo.
    HTH
    MarkN.
  • Hi Mark,
    Thank you for the update about repo tool.
    I just ran the script successfully with the comande $ jenkins-setup/init-and-build.sh . However, once I switched back to the $OE_HOME, I cannot find any program named oe-init-build-env and I cannot execute the commands:
    $ cd ./bitbake/bin
    $ export PATH=`pwd`:$PATH
    My output of init-and-build.sh is:
    ### Shell environment set up for builds. ###
    You can now run 'bitbake <target>'
    Common targets are:
        core-image-minimal
        core-image-sato
        meta-toolchain
        meta-ide-support
    You can also run generated qemu images with a command like 'runqemu qemux86'
    Nothing to do.  Use 'bitbake world' to build everything, or run 'bitbake --help' for usage information.
    NOTE: Your conf/bblayers.conf has been automatically updated.
    Right now my$OE_HOME directory only contains 8 folders:
    simonwan@I-Love-Research:~/oe_build$ ls
    build          meta-96boards  meta-linaro        meta-virtualization
    jenkins-setup  meta-browser   meta-openembedded  openembedded-core
    Do you think I still missed some component for building OE?
    Sorry for so many questions. I know for most case we don't need to build OE by ourselves while I'm currently conducting some research experiments about ARM TrustZone and I need to rebuild the normal OS with some functions for experiment evaluation.
    Bests,
    Simon
  • Hi,
    Have you tried searching?
    markn@psg-markn2:/media/markn/1TB_HDD/junk/openembedded$ find ./ -name "oe-init-build-env"
    ./openembedded-core/oe-init-build-env
    I'll update the instructions to:
    cd ./openembedded-core/
    ./oe-init-build-env
    Regards
    MarkN.
  • Hi,
    That should start the build. However I'm afraid it looks like there are other problems with the bitbake recipes ad the build fails for me. I've raise this with Linaro. Sorry.
    MarkN.
