[bug] Unexpected optimization strategy (arm-none-eabi-gcc 15)
#include <stdint.h>
#include <stddef.h>
 * Name:    CRC-32/MPEG-2  x32+x26+x23+x22+x16+x12+x11+x10+x8+x7+x5+x4+x2+x+1
 * Poly:    0x4C11DB7
 * Init:    0xFFFFFFF
 * Refin:   False
 * Refout:  False
 * Xorout:  0x0000000
 * Note:
uint32_t crc32(const uint8_t *data, size_t length)
    uint8_t i;
    uint32_t crc = 0xffffffff; // Initial value
    while (length--) {
        crc ^= (uint32_t)(*data++) << 24;
        for (i = 0; i < 8; ++i) {
            if (crc & 0x80000000)
                crc = (crc << 1) ^ 0x04C11DB7;
            else
                crc <<= 1;
    return crc;
For this code, the Os/Oz option results in generating larger code than O3.
https://godbolt.org/z/MEqqK1q5T
Section size for -Os options
|     .text |    .data |     .bss |  .rodata |
|    44(+0) |    0(+0) |    0(+0) | 1024(+0) |
Section size for -O3 options
|   104(+0) |    0(+0) |    0(+0) |    0(+0) |
The behavior is normal on gcc 10.3.1.
  • Hi  !
    The code (.text segment) is definitely smaller with -Os then -O3, but GCC 15.2 uses/places some read-only variables into the .rodata segment. I don't have GCC 10.3.1 here but you could test which optimization option does this.
    You can invoke GCC following to see enabled/disabled optimization options at the specific level:
    For -Os:
    $ arm-none-eabi-gcc --help=optimizers -Q -Os
    The following options control optimizations:
      --param=lto-partition-locality-cloning=       maximal
      -O<number>
      -Ofast
      -Og
      -Os
      -Oz
      -faggressive-loop-optimizations       [enabled]
      -falign-functions                     [disabled]
      -falign-functions=
      -falign-jumps                         [disabled]
      -falign-jumps=
      -falign-labels                        [disabled]
      -falign-labels=
      -falign-loops                         [disabled]
      -falign-loops=
      -fallocation-dce                      [enabled]
      -fallow-store-data-races              [disabled]
      -fassociative-math                    [disabled]
      -fassume-sane-operators-new-delete    [available in C++, ObjC++]
      -fasynchronous-unwind-tables          [disabled]
      -fauto-inc-dec                        [enabled]
      -favoid-store-forwarding              [disabled]
      -fbit-tests                           [enabled]
      -fbranch-count-reg                    [enabled]
      -fbranch-probabilities                [disabled]
      -fcaller-saves                        [enabled]
      -fcode-hoisting                       [enabled]
      -fcombine-stack-adjustments           [enabled]
      -fcompare-elim                        [enabled]
      -fconserve-stack                      [disabled]
      -fcprop-registers                     [enabled]
      -fcrossjumping                        [enabled]
      -fcse-follow-jumps                    [enabled]
      -fcx-fortran-rules                    [disabled]
      -fcx-limited-range                    [disabled]
      -fdce                                 [enabled]
      -fdefer-pop                           [enabled]
      -fdelayed-branch                      [disabled]
      -fdelete-dead-exceptions              [disabled]
      -fdelete-null-pointer-checks
      -fdevirtualize                        [enabled]
      -fdevirtualize-speculatively          [enabled]
      -fdse                                 [enabled]
      -fearly-inlining                      [enabled]
      -fexceptions                          [available in D, Modula-2]
      -fexcess-precision=[fast|standard|16]         [default]
      -fexpensive-optimizations             [enabled]
      -fext-dce                             [enabled]
      -ffast-math
      -ffinite-loops                        [disabled]
      -ffinite-math-only                    [disabled]
      -ffloat-store                         [disabled]
      -ffold-mem-offsets                    [enabled]
      -ffold-simple-inlines                 [available in C++, ObjC++]
      -fforward-propagate                   [enabled]
      -ffp-contract=[off|on|fast]           fast
      -ffp-int-builtin-inexact              [enabled]
      -ffunction-cse                        [enabled]
      -fgcse                                [enabled]
      -fgcse-after-reload                   [disabled]
      -fgcse-las                            [disabled]
      -fgcse-lm                             [enabled]
      -fgcse-sm                             [disabled]
      -fgraphite                            [disabled]
      -fgraphite-identity                   [disabled]
      -fguess-branch-probability            [enabled]
      -fhandle-exceptions                   -fexceptions
      -fhardcfr-check-exceptions
      -fhardcfr-check-noreturn-calls=[always|no-xthrow|nothrow|never]       [default]
      -fhardcfr-check-returning-calls
      -fhardcfr-skip-leaf                   [disabled]
      -fharden-compares                     [disabled]
      -fharden-conditional-branches         [disabled]
      -fharden-control-flow-redundancy      [disabled]
      -fhoist-adjacent-loads                [enabled]
      -fif-conversion                       [enabled]
      -fif-conversion2                      [enabled]
      -findirect-inlining                   [enabled]
      -finline                              [enabled]
      -finline-atomics                      [enabled]
      -finline-functions                    [enabled]
      -finline-functions-called-once        [enabled]
      -finline-small-functions              [enabled]
      -finline-stringops                    [disabled]
      -finline-stringops=                   [default]
      -fipa-bit-cp                          [enabled]
      -fipa-cp                              [enabled]
      -fipa-cp-clone                        [disabled]
      -fipa-icf                             [enabled]
      -fipa-icf-functions                   [enabled]
      -fipa-icf-variables                   [enabled]
      -fipa-modref                          [enabled]
      -fipa-profile                         [enabled]
      -fipa-pta                             [disabled]
      -fipa-pure-const                      [enabled]
      -fipa-ra                              [enabled]
      -fipa-reference                       [enabled]
      -fipa-reference-addressable           [enabled]
      -fipa-reorder-for-locality            [disabled]
      -fipa-sra                             [enabled]
      -fipa-stack-alignment                 [enabled]
      -fipa-strict-aliasing                 [enabled]
      -fipa-vrp                             [enabled]
      -fira-algorithm=[CB|priority]         CB
      -fira-hoist-pressure                  [enabled]
      -fira-loop-pressure                   [disabled]
      -fira-region=[one|all|mixed]          one
      -fira-share-save-slots                [enabled]
      -fira-share-spill-slots               [enabled]
      -fisolate-erroneous-paths-attribute   [disabled]
      -fisolate-erroneous-paths-dereference         [enabled]
      -fivopts                              [enabled]
      -fjump-tables                         [enabled]
      -fkeep-gc-roots-live                  [disabled]
      -flate-combine-instructions           [enabled]
      -flifetime-dse                        [enabled]
      -flifetime-dse=<0,2>                  2
      -flimit-function-alignment            [disabled]
      -flive-patching                       -flive-patching=inline-clone
      -flive-patching=[inline-only-static|inline-clone]     [default]
      -flive-range-shrinkage                [disabled]
      -floop-interchange                    [disabled]
      -floop-nest-optimize                  [disabled]
      -floop-parallelize-all                [disabled]
      -floop-unroll-and-jam                 [disabled]
      -flra-remat                           [enabled]
      -fmalloc-dce                          [enabled]
      -fmalloc-dce=<0,2>                    0
      -fmath-errno                          [enabled]
      -fmin-function-alignment=             0
      -fmodulo-sched                        [disabled]
      -fmodulo-sched-allow-regmoves         [disabled]
      -fmove-loop-invariants                [enabled]
      -fmove-loop-stores                    [enabled]
      -fno-inline-stringops                 [enabled]
      -fnon-call-exceptions                 [disabled]
      -fnothrow-opt                         [available in C++, ObjC++]
      -fomit-frame-pointer                  [enabled]
      -fopenmp-target-simd-clone=           none
      -fopt-info                            [disabled]
      -foptimize-crc                        [enabled]
      -foptimize-sibling-calls              [enabled]
      -foptimize-strlen                     [disabled]
      -fpack-struct                         [disabled]
      -fpack-struct=<number>
      -fpartial-inlining                    [enabled]
      -fpatchable-function-entry=
      -fpcc-struct-return                   [disabled]
      -fpeel-loops                          [disabled]
      -fpeephole                            [enabled]
      -fpeephole2                           [enabled]
      -fplt                                 [enabled]
      -fpredictive-commoning                [disabled]
      -fprefetch-loop-arrays
      -fprintf-return-value                 [enabled]
      -fprofile-partial-training            [disabled]
      -fprofile-reorder-functions           [disabled]
      -freciprocal-math                     [disabled]
      -free                                 [disabled]
      -freg-struct-return                   -fpcc-struct-return
      -frename-registers                    [disabled]
      -freorder-blocks                      [enabled]
      -freorder-blocks-algorithm=[simple|stc]       simple
      -freorder-blocks-and-partition        [disabled]
      -freorder-functions                   [enabled]
      -frerun-cse-after-loop                [enabled]
      -freschedule-modulo-scheduled-loops   [disabled]
      -frounding-math                       [disabled]
      -frtti                                [available in C++, D, ObjC++]
      -fsave-optimization-record            [disabled]
      -fsched-critical-path-heuristic       [enabled]
      -fsched-dep-count-heuristic           [enabled]
      -fsched-group-heuristic               [enabled]
      -fsched-interblock                    [enabled]
      -fsched-last-insn-heuristic           [enabled]
      -fsched-pressure                      [enabled]
      -fsched-rank-heuristic                [enabled]
      -fsched-spec                          [enabled]
      -fsched-spec-insn-heuristic           [enabled]
      -fsched-spec-load                     [disabled]
      -fsched-spec-load-dangerous           [disabled]
      -fsched-stalled-insns                 [disabled]
      -fsched-stalled-insns-dep             [enabled]
      -fsched-stalled-insns-dep=<number>
      -fsched-stalled-insns=<number>
      -fsched2-use-superblocks              [disabled]
      -fschedule-fusion                     [disabled]
      -fschedule-insns                      [disabled]
      -fschedule-insns2                     [enabled]
      -fsection-anchors                     [enabled]
      -fsel-sched-pipelining                [disabled]
      -fsel-sched-pipelining-outer-loops    [disabled]
      -fsel-sched-reschedule-pipelined      [disabled]
      -fselective-scheduling                [disabled]
      -fselective-scheduling2               [disabled]
      -fsemantic-interposition              [enabled]
      -fshort-enums                         [disabled]
      -fshort-wchar                         [disabled]
      -fshrink-wrap                         [enabled]
      -fshrink-wrap-separate                [enabled]
      -fsignaling-nans                      [disabled]
      -fsigned-zeros                        [enabled]
      -fsimd-cost-model=[unlimited|dynamic|cheap|very-cheap]        unlimited
      -fsingle-precision-constant           [disabled]
      -fsplit-ivs-in-unroller               [enabled]
      -fsplit-loops                         [disabled]
      -fsplit-paths                         [disabled]
      -fsplit-wide-types                    [enabled]
      -fsplit-wide-types-early              [disabled]
      -fssa-backprop                        [enabled]
      -fssa-phiopt                          [enabled]
      -fstack-check=[no|generic|specific]
      -fstack-clash-protection              [disabled]
      -fstack-protector                     [disabled]
      -fstack-protector-all                 [disabled]
      -fstack-protector-explicit            [disabled]
      -fstack-protector-strong              [disabled]
      -fstack-reuse=[all|named_vars|none]   all
      -fstdarg-opt                          [enabled]
      -fstore-merging                       [enabled]
      -fstrict-aliasing                     [enabled]
      -fstrict-enums                        [available in C++, ObjC++]
      -fstrict-volatile-bitfields           [enabled]
      -fthread-jumps                        [enabled]
      -fno-threadsafe-statics               [available in C++, ObjC++]
      -ftoplevel-reorder                    [enabled]
      -ftracer                              [disabled]
      -ftrapping-math                       [enabled]
      -ftrapv                               [disabled]
      -ftree-bit-ccp                        [enabled]
      -ftree-builtin-call-dce               [enabled]
      -ftree-ccp                            [enabled]
      -ftree-ch                             [enabled]
      -ftree-coalesce-vars                  [enabled]
      -ftree-copy-prop                      [enabled]
      -ftree-cselim                         [disabled]
      -ftree-dce                            [enabled]
      -ftree-dominator-opts                 [enabled]
      -ftree-dse                            [enabled]
      -ftree-forwprop                       [enabled]
      -ftree-fre                            [enabled]
      -ftree-loop-distribute-patterns       [enabled]
      -ftree-loop-distribution              [disabled]
      -ftree-loop-if-convert
      -ftree-loop-im                        [enabled]
      -ftree-loop-ivcanon                   [enabled]
      -ftree-loop-optimize                  [enabled]
      -ftree-loop-vectorize                 [disabled]
      -ftree-lrs                            [disabled]
      -ftree-parallelize-loops=<number>     1
      -ftree-partial-pre                    [disabled]
      -ftree-phiprop                        [enabled]
      -ftree-pre                            [enabled]
      -ftree-pta                            [enabled]
      -ftree-reassoc                        [enabled]
      -ftree-scev-cprop                     [enabled]
      -ftree-sink                           [enabled]
      -ftree-slp-vectorize                  [disabled]
      -ftree-slsr                           [enabled]
      -ftree-sra                            [enabled]
      -ftree-switch-conversion              [enabled]
      -ftree-tail-merge                     [enabled]
      -ftree-ter                            [enabled]
      -ftree-vectorize                      [disabled]
      -ftree-vrp                            [enabled]
      -ftrivial-auto-var-init=[uninitialized|pattern|zero]  uninitialized
      -funconstrained-commons               [disabled]
      -funreachable-traps                   [disabled]
      -funroll-all-loops                    [disabled]
      -funroll-completely-grow-size         [disabled]
      -funroll-loops                        [disabled]
      -funsafe-math-optimizations           [disabled]
      -funswitch-loops                      [disabled]
      -funwind-tables                       [disabled]
      -fvar-tracking                        [disabled]
      -fvar-tracking-assignments            [disabled]
      -fvar-tracking-assignments-toggle     [disabled]
      -fvar-tracking-uninit                 [disabled]
      -fvariable-expansion-in-unroller      [disabled]
      -fvect-cost-model=[unlimited|dynamic|cheap|very-cheap]        very-cheap
      -fversion-loops-for-strides           [disabled]
      -fvpt                                 [disabled]
      -fweb                                 [disabled]
      -fwrapv                               [disabled]
      -fwrapv-pointer                       [disabled]
      -gstatement-frontiers                 [disabled]
    For -O3:
    $ arm-none-eabi-gcc --help=optimizers -Q -O3
      -O<number>
      -Ofast
      -Og
      -Os
      -Oz
      -falign-functions                     [enabled]
      -falign-functions=                    4
      -falign-jumps                         [enabled]
      -falign-jumps=
      -falign-labels                        [enabled]
      -falign-labels=
      -falign-loops                         [enabled]
      -falign-loops=
      -fdce                                 [enabled]
      -fdse                                 [enabled]
      -fext-dce                             [enabled]
      -ffast-math
      -fgcse                                [enabled]
      -fgcse-after-reload                   [enabled]
      -fgcse-lm                             [enabled]
      -finline                              [enabled]
      -fipa-cp                              [enabled]
      -fipa-cp-clone                        [enabled]
      -fipa-icf                             [enabled]
      -fipa-ra                              [enabled]
      -fipa-sra                             [enabled]
      -fipa-vrp                             [enabled]
      -fivopts                              [enabled]
      -floop-interchange                    [enabled]
      -floop-unroll-and-jam                 [enabled]
      -fopenmp-target-simd-clone=           nohost
      -foptimize-strlen                     [enabled]
      -fpeel-loops                          [enabled]
      -fplt                                 [enabled]
      -fpredictive-commoning                [enabled]
      -free                                 [disabled]
      -freorder-blocks-algorithm=[simple|stc]       stc
      -fschedule-insns                      [enabled]
      -fsplit-loops                         [enabled]
      -fsplit-paths                         [enabled]
      -ftracer                              [disabled]
      -ftrapv                               [disabled]
      -ftree-ch                             [enabled]
      -ftree-loop-distribution              [enabled]
      -ftree-loop-vectorize                 [enabled]
      -ftree-partial-pre                    [enabled]
      -ftree-slp-vectorize                  [enabled]
      -funroll-completely-grow-size         [enabled]
      -funswitch-loops                      [enabled]
      -fvect-cost-model=[unlimited|dynamic|cheap|very-cheap]        dynamic
      -fversion-loops-for-strides           [enabled]
      -fvpt                                 [disabled]
      -fweb                                 [disabled]
      -fwrapv                               [disabled]
    Just compare the output to narrow down the issue and feel free to open a bug report at the GCC bugtracker.
  • I think it should be this option: -foptimize-crc
    The Docs:
    -foptimize-crc
    Detect loops calculating CRC (performing polynomial long division) and replace them with a faster implementation. Detect 8, 16, 32, and 64 bit CRC, with a constant polynomial without the leading 1 bit, for both bit-forward and bit-reversed cases. If the target supports a CRC instruction and the polynomial used in the source code matches the polynomial used in the CRC instruction, generate that CRC instruction. Otherwise, if the target supports a carry-less-multiplication instruction, generate CRC using it; otherwise generate table-based CRC.
    Enabled by default at and higher. -O2
    When i use `-Os -fno-optimize-crc`, code size (.text + .rodata) become normal.
    Yes, seems correct for me.
    Was implemented on 11. November 2024 with git commit 062ad209e496a69925b1ac1d80d9b99c54801830:
    Author: Mariam Arutunian <mariamarutunian@gmail.com>
    Date:   Mon Nov 11 12:59:04 2024 -0700
        [PATCH v7 08/12] Add a new pass for naive CRC loops detection
        This patch adds a new compiler pass aimed at identifying naive CRC
        implementations, characterized by the presence of a loop calculating
        a CRC (polynomial long division).  Upon detection of a potential CRC,
        the pass prints an informational message.
        Performs CRC optimization if optimization level is >= 2 and if
        fno_gimple_crc_optimization given.
        This pass is added for the detection and optimization of naive CRC
        implementations, improving the efficiency of CRC-related computations.
        This patch includes only initial fast checks for filtering out non-CRCs,
        detected possible CRCs verification and optimization parts will be
        provided in subsequent patches.
        gcc/
                * Makefile.in (OBJS): Add gimple-crc-optimization.o.
                * common.opt (foptimize-crc): New option.
                * common.opt.urls: Regenerate to add foptimize-crc.
                * doc/invoke.texi (-foptimize-crc): Add documentation.
                * gimple-crc-optimization.cc: New file.
                * opts.cc (default_options_table): Add OPT_foptimize_crc.
                (enable_fdo_optimizations): Enable optimize_crc.
                * passes.def (pass_crc_optimization): Add new pass.
                * timevar.def (TV_GIMPLE_CRC_OPTIMIZATION): New timevar.
                * tree-pass.h (make_pass_crc_optimization): New extern function
                declaration.
    GCC 10.3.x was released on 8. April 2021:
    commit f00b5710a30f22efc3171c393e56aeb335c3cd39 (HEAD, tag: releases/gcc-10.3.0)
    Author: Richard Biener <rguenther@suse.de>
    Date:   Thu Apr 8 11:56:48 2021 +0000
        Update ChangeLog and version files for release
  • Hi,
    Thanks for the report. I've committed a fix for this in commit 26e88fe809de0f1a1812c99e2e0106afb03257b3 and it'll be in GCC 15.3.
  • Ok, and thanks for your work.
