Cannot build position independent code that works
I'm building code for NXP S32K148 MCU (Arm Cortex M4F) and I need to build code which is position independent. I'm using gcc 6.3.1 provided by NXP.
I've almost managed to make it work...
1. I set the compile options "-fpic -msingle-pic-base -mno-pic-data-is-text-relative -mpic-register=r9".
2. I modified startup code:
   a. Calculate offset between compile time and run-time program counter (relocation offset).
   b. Copy the global offsets table to RAM while fixing code addresses by the relocation offset.
   c. Fix the interrupts vectors table pointers by the relocation offset.
   d. Set R9 to point to the global offsets table.
It worked - except that any function pointers inside initialized variable/structs were not relocated and were not accessed through the global offsets table. When execution reached such a pointer the system of course crashed.
Does anyone have a solution?
Freddy
  • Hello Freddy,
    From my understanding I think you don't need to fix code addresses or even the pointers stored within the vector table as they are all using relative addresses.
    That said, if you aim to build an executable and not a library, you may focus on compiling and linking your code as for a position independent executable:
    - for compilation use -fPIE
    - for linking user -fPIE -pie
    For any library used by your executable, make sure they have been compiled and linked with -fPIC argument. Note sure about standard libs though...
    Since the libraries are shared PIC, they shall be loaded separately before your PIE. For both libraries and the final executable, parse the respective GOT base addresses during startup code.
    Before handoff to the executable, make sure the vector base address (VBAR) is set to the right address.
    Regards,
    Florian
  • Hi Freddy, did you manage to find a solution for this issue in gcc? I only found that in arm toolchain and in iar toolchain there is this -ropi switch (read only position independent) which solves exactly this problem, but struggling to find something similar in gcc.
  • I could not find a good solution. The main problem (as far as I remember) had to do with pointers in static structure and I could not avoid them in runtime library.
    We didn't need completely position independent code, just needed builds for two images A & B (to allow running from one while updating the other), so we solved the problem by always building both and deciding at boot time which to use and which to update.
  • Hello.
    Fortunately, I solved this problem yesterday.
    A workaround is to use "-fPIC" + "-mno-pic-data-is-text-relative" for the compile option and add "-shared" + "-symbolic" for the Link option.
    Of course, by using "-shared", ELF was changed to a shared object file rather than an executable, but
    The desired Dynamic Segment and Relocation Section have been created,
    We were able to proceed with relocation using this.
    Additionally, there is a symptom that the binary size increases as external APIs are included in the ELF.
    And, I didn't process the relocation information that I couldn't understand.
    I'll leave an answer for your reference to the same problem as me in the future.
    Good work, and have a nice day today.​
