Site
Search
User
Site
Search
User
Forums
Compilers and Libraries forum
armlink: symdefs generation
Jump...
Cancel
State
Not Answered
Locked
Locked
Replies
Subscribers
19 subscribers
Views
Users
0 members are here
armlink
compiler
Options
More actions
Cancel
Related
Aleph1024
over 13 years ago
Note: This was originally posted on 19th November 2008 at
http://forums.arm.com
Hi all,
I use ARM linker, ADS1.2 [Build 848].
I found some strangeness with generation of the Symbol Definitions file.
So, what I do, step by step (with CodeWarrior):
1. Project->Remove Object Code
2. Make
The symdefs file is created, and
89
global symbols are written to the symdefs file.
After that I repeat:
3. Project->Remove Object Code (symdefs file is not deleted automatically).
4. Make
The symdefs file is
re
built, but only
67
global symbols have been remained in the symdefs file.
As I change nothing, just rebuild the project, I expect that the number of global symbols must not be changed, and as a result the symdefs file should be identical to the previously created.
Please, could somebody explain me where I am wrong? And, what do I have to do to avoid this problem?
Thank you,
Alexandre.
0
arunjr
over 13 years ago
Note: This was originally posted on 27th November 2008 at
Hi Aleph1024,
do you have --feedback option enabled for your linker?
ref : RVCT linker and Utilities guide , chapter - 3.3.5. Linker feedback
(--feedback is used to strip down the unused symbols during linking, during 'second build'.)
and if the problem still persists, just try compiling with no optimization options(remove the inlining options too) and see whether the symdef file generated are still the holding good every time. But anyways, plz post the result. its interesting to know the answer.
good luck.
cheers
Aj
Cancel
Vote up
0
Vote down
Cancel
0
arunjr
over 13 years ago
Hi Aleph1024,
good luck.
cheers
Aj
Cancel
Vote up
0
Vote down
Cancel
