Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
[Cortex-M3] Execution code from RAM during Flash Programming
Jump...
Cancel
Locked
Locked
Replies
Subscribers
118 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Rohit Pathak
over 13 years ago
I am writing a bootloader for Cortex M3 Toshiba controller.
During Flash Programming I need to execute code from RAM as entire Flash is inaccessible during write/erase operations
I wish to know how to copy code from FLASH to RAM and execute that code from RAM.
Thanks...
Joseph Yiu
over 13 years ago
Note: This was originally posted on 15th March 2012 at
http://forums.arm.com
Hi Rohit,
In this case you could develop the bootloader and flash programming code as two separate projects.
The flash programming project is compiled and link using SRAM as program address.
Then you can generate hex image, and insert this into your boot loader project as a constant array.
Inside your boot loader, you can copy this constant array into SRAM.
To jump from boot loader to flash programming code, personally I got used to use embedded assembly:
/* ARM RVDS or Keil MDK */
__asm void jump_to_sram(void)
LDR R0,=0x20000000 ; starting address of program in SRAM.
LDR R1,[R0] ; Get initial MSP value
MOV SP, R1 ; Set SP value
LDR R1,[R0, #4] ; Get initial PC value
BX R1
You can use function pointer to do the same.
regards,
Joseph
Cancel
Vote up
0
Vote down
Cancel
Joseph Yiu
over 13 years ago
Hi Rohit,
BX R1
regards,
Joseph
Cancel
Vote up
0
Vote down
Cancel
