Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Q: Why ARM generates undefined instruction exception but PC and instruction are both OK
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
yuan shao
over 13 years ago
Dear All,
I have met some problem which holds me for almost 2 weeks. I worked on some ARM926EJ-S based chip. The code sometime can run up to 2-3 days with no problem, but sometime after few hours running, ARM generated "undefined instruction" exception. I use the ICE debugger to trace the problem, the value in "lr" is good, in terms of it is within well defined code area. So I did one experiment, in the "undefined exception handler", I just simply set the PC back to the "lr", and the code can resume without any problem. In my case, I turn on the Icache and Dcache.
Does anyone have the similar experience before? or Any idea? Thanks a lot!
Ys1234
Charlie Jung
over 13 years ago
Note: This was originally posted on 19th March 2012 at
http://forums.arm.com
Hi YS1234,
For checking external memory, I'd like to suggest relocation of your code to different address of external memory.
One more thing for checking internal path or cache line fill, you could add one or two 'NOP' prior to the problematic instruction and see what's different.
Thanks,
Charlie
Cancel
Vote up
0
Vote down
Cancel
Charlie Jung
over 13 years ago
Hi YS1234,
Thanks,
Charlie
Cancel
Vote up
0
Vote down
Cancel
