Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Q: Compile program using Makefile under RVDS 4.0
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
unifoxz Fox
over 13 years ago
Note: This was originally posted on 28th February 2012 at
http://forums.arm.com
I have a sample program together with its Makefile.
May I know how to run the Makefile to compile the C programs under RVDS 4.0?
Thank you.
unifoxz Fox
over 13 years ago
Thank you, Joseph.
Sorry that I didn't make my question clear enough.
I was unable to source to ARM compile toolchain, such as ARMCC, ARMASM etc, provided by RVDS installed on Windows.
I was then installed the RVDS on linux platform and found the path to the compiler tools, as followed:
/ARM/RVCT/Programs/4.0/400/linux-pentium/
However my compilation shows the error of "cannot open source input file "string.h": No such file or directory".
If there is anyone know about the solution, please kindly advice.
Thank you.
Cancel
Vote up
0
Vote down
Cancel
unifoxz Fox
over 13 years ago
I have solved the problem.
It requires manually define include directory to /ARM/RVCT/Data/4.0/400/include/unix/ and also define libpath to /ARM/RVCT/Data/4.0/400/lib/armlib/ & /ARM/RVCT/Data/4.0/400/lib/cpplib/
Thanks.
Cancel
Vote up
0
Vote down
Cancel
Joseph Yiu
over 13 years ago
If you are running Linux, you can usually use the makefile as:
$> make something
For example, most makefiles will have a "all" target, so you can simply run
$> make all
If you can post your makefile here can can give you more details.
regards,
joseph
Cancel
Vote up
0
Vote down
Cancel
