Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
ARMASM: produce preprocessed output
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
John Doe
over 13 years ago
Note: This was originally posted on 6th February 2012 at
http://forums.arm.com
with armcc I can generate assembly listing by using --asm command line option. How can I do the same with armasm? The reason I want to do it is because of that unreadable macros used by armasm, in short I want all macro expanded and see regular asm listing (same as if I disassembled the obj file). The --asm option does the job very well, is there similar option I can use with armasm?
thanks
John Doe
over 13 years ago
armas help gives that list option at the beginning of the help text. However, this option gives even more crippled listing than the original asm file. It's nowhere near as the output that armcc --asm gives.
Cancel
Vote up
0
Vote down
Cancel
Bastian Schick
over 13 years ago
Hmm, did you try looking into the manual. There is --list !
Cancel
Vote up
0
Vote down
Cancel
Peter Harris
over 13 years ago
Note: This was originally posted on 7th February 2012 at
Hmm, I'd try assembling it to object form, and then using objdump/fromelf to disassemble the object.
I'm not aware of a preprocessor for the assembler macros.
Cancel
Vote up
0
Vote down
Cancel
