Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Monitor stack pointer configuration in non secure mode
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
naveen venugopal
over 13 years ago
Note: This was originally posted on 28th December 2011 at
http://forums.arm.com
Hi
Please help me to understand whether the monitor stack pointer has to be configured in the non secure mode in the boot sequence.
I understand that all the other stack pointers(usr, svc, fiq ,irq ) has to be configured for the non secure area.
But should i configure the monitor stack pointer also in non secure mode????
Please help
naveen venugopal
over 13 years ago
Note: This was originally posted on 2nd January 2012 at
hi ...
@something..
Does this mean that I have to initialise a pointer for sp_mon register in non secure mode?
I do understand that i have to initialise stack pointer fro monitor in secure mode....but when cpu in monitor mode goes from secure to non secure, do we have to separetely initialise SP_MON register in non sec mode?
Cancel
Vote up
0
Vote down
Cancel
something wrong
over 13 years ago
Note: This was originally posted on 31st December 2011 at
monitor mode SP is banked. That means you can only configure it in monitor mode.
A only entry is boot up.When booting,the arm is in secure mode,you must install your monitor code before you return non-secure mode.
Otherwise, you can do nothing in secure mode.
Cancel
Vote up
0
Vote down
Cancel
Peter Harris
over 13 years ago
Monitor mode is a secure mode, so you won't be able to set up the stack pointer =)
Cancel
Vote up
0
Vote down
Cancel
Martin Weidmann
over 13 years ago
Note: This was originally posted on 3rd January 2012 at
Simple answer is - no.
You have a "Secure Monitor" which is a bit of software responsible for switching between the Secure and Normal worlds. The "Secure Monitor" software executes mainly in "Monitor mode". When the processor is "Monitor mode" it is ALWAYS in the Secure world.
To initialize any of the Monitor mode registers (lr_mon, sp_min, spsr_mon) you need to be in Monitor mode. Whenever you are in Monitor mode you are in the Secure world.
As something said, the boot code for the Secure world will be responsible for setting up Monitor mode/Secure Monitor. The Normal world code should not need to do anything related to the Monitor.
Cancel
Vote up
0
Vote down
Cancel
