Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
c5, Instruction Fault Status Register
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Michail Bakunin
over 13 years ago
Note: This was originally posted on 5th January 2012 at
http://forums.arm.com
I have implemented a MMU logic for the Cortex A8 on the BeagleBoard. It seems to work well. But after handling the first data abort and creating a page because no page is present right now, I am getting a prefetch abort with the State 1008 (hex) which means: b
x
01000 precise external abort, nontranslation (found at
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ddi0344k/Bgbjhija.html
But I have no clue what that means. Can someone please give me some more information about this error? If you need more information don't hesitate to ask me.
Thanks in advance,
Michail
Michail Bakunin
over 13 years ago
Note: This was originally posted on 8th January 2012 at
Thank you for your quick response.
I just solved the problem. When I received an interrupt I did set the master table pointer to the kernel's master table address, but didn't set it back to the calling process' master table.
Cancel
Vote up
0
Vote down
Cancel
Martin Weidmann
over 13 years ago
Note: This was originally posted on 6th January 2012 at
It means that the address translation processor "succeeded". That is, the processor was able to read the translation table, and the entry marks the memory as read/executable.
But that when it then accessed the physical address specified by the translation table entry, the memory system returned an error.
Cancel
Vote up
0
Vote down
Cancel
