Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
A8/9 NEON 128bit registers, 64bit alu's
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Sander Bogaert
over 13 years ago
Note: This was originally posted on 1st December 2011 at
http://forums.arm.com
I've been reading a lot about the neon architecture for a project but there is still this one thing I'm not entirely sure about. If I understand correctly the 128bit-view is more of an aid for the programmer since the alu's in the neon engine are only 64bit wide instructions working on a qx register will just take double the time. I was going over the timing tables trying my best to understand them :-) and saw this confirmed in some instruction timings but in other the operation on 128bit would also just take one cycle ( add for example ).
Did I read the table wrong? If not: how is this achieved? Is this divided over 2 64bit adders which are coupled ( carry ) then?
Thanks in advance
Shervin Emami
over 13 years ago
Note: This was originally posted on 10th December 2011 at
It's true that NEON has 128-bit registers but nearly always operates on just 64-bits at a time. But the size of the registers is an Architecture (language) specification that can't change whereas the internal use of 64-bits is an implementation issue that will change over time, so you can expect that perhaps in 1 more year, ARM devices will operate on 128-bits at a time instead of 64-bits. So if you write your NEON code now for 128-bit, it will be more future proof because the same code will potentially double in speed in the future!
Cheers,
Shervin Emami.
http://www.shervinem...rmAssembly.html
Cancel
Vote up
0
Vote down
Cancel
Shervin Emami
over 13 years ago
Cheers,
Shervin Emami.
Cancel
Vote up
0
Vote down
Cancel
