Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Moving stack from TCM to external DDR2 SDRAM
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Kevin Schaffer
over 13 years ago
Kevin Schaffer
over 13 years ago
Note: This was originally posted on 17th November 2011 at
http://forums.arm.com
Ok, figured it out.
That setup seems to be A-Ok, as far as I know (let me know otherwise). However, when filling the stack with a pattern (which I was doing by accessing the SP) instead of starting at the SP - 4 (going lower in addresses) I was starting at SP.
There may be other things wrong, but at least my stack analysis seems to be ok and not crashing into Abort_Handler now.
Cancel
Vote up
0
Vote down
Cancel
Kevin Schaffer
over 13 years ago
Note: This was originally posted on 22nd November 2011 at
One more question: In a given function, does SP point to the highest used address on the stack? Or does it point to, say, the first used address of the local function, and, if the local function used, say, 12 bytes, SP, SP - 4, and SP - 8 are all used, so if I was looking for the address of the first *unused* byte (4-byte) location, I'd have to look at SP - 12?
Cancel
Vote up
0
Vote down
Cancel
Gilead Kutnick
over 13 years ago
Note: This was originally posted on 23rd November 2011 at
SP points to the last thing that was allocated on the stack, unless the stack is empty, in which case it points right past the stack. So if you allocate 3 words in a function they'll be accessible at [ sp ], [ sp + 4 ], and [ sp + 8 ]. The allocation itself will be performed by subtracting 12 from the stack pointer. Unallocated memory starts immediately at addresses below the stack pointer.
Cancel
Vote up
0
Vote down
Cancel
