Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Strange behaviour of cache
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
qwerty ytrewq
over 13 years ago
Note: This was originally posted on 19th November 2011 at
http://forums.arm.com
Hi!
I have a Cortex a9 based board (currently only 1core is active another one is waiting for its time to come into a play).
My simplified caching routine in pseudo code looks like this:
Cache(set of parameters){
if(cache_op1)docache_op1();
if(cache_op2)docache_op2();
if(cache_opn)docache_opn();
An example of cache operation:
mov r0, #0
mcr p15, 0, r0, c7, c5, 0 ; I cache
mcr p15, 0, r0, c7, c5, 6 ; BP
DSB
ISB
bx lr
The system hangs at some point...
But when I include a delay (several thousands of CPU cycles) it gets stable and works just fine:
Delay();
Disabling/enabling L2 cache doesn't seem to affect the system. So I think it is related to L1 cache.
Having delay in this function isn't acceptable because of performance issues and frankly speaking I don't know how long it should be delayed for in every particular case.
I suspect that some caching operations need time to complete. Is there a mechanism in ARM to ensure that caching operation is complete? I thought it was done by using the DSB instruction... But it is either ignored or used for a completely different purpose. If there is no such mechanism then how should it be handled? I mean if the program continues to execute while hardware operation is not finished. Otherwise I cannot explain my workaround with delay. Any ideas are welcome.
Jerry Fan
over 13 years ago
HI SJS,
Maybe you can remove the delay at the end of the function and add delay to the cache_ops to see which cache op result the issue. Such as
[color=#222222][size=2]if(cache_op2){ docache_op2(); delay()}[/size][/color]
[color=#222222][size=2]Please try add some nops to then end of the docache_ops, such as[/size][/color]
[color=#222222][size=2] [/size][/color][color=#222222][size=2]mov r0, #0[/size][/color][color=#222222][size=2] mcr p15, 0, r0, c7, c5, 0 ; I cache [/size][/color]
[color=#222222][size=2] mcr p15, 0, r0, c7, c5, 6 ; BP[/size][/color]
[color=#222222][size=2] DSB[/size][/color]
[color=#222222][size=2] ISB[/size][/color]
nop
nop
nop
[color=#222222][size=2] bx lr[/size][/color]
[color=#222222][size=2]to clean the pipeline.[/size][/color]
Cancel
Vote up
0
Vote down
Cancel
Jerry Fan
over 13 years ago
HI SJS,
nop
nop
nop
Cancel
Vote up
0
Vote down
Cancel
