Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
cache maintenance on cortex-a8
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Jerry Fan
over 13 years ago
Note: This was originally posted on 17th November 2011 at
http://forums.arm.com
[size=2]Hi ARM experts,
I am a little confused about the cache maintenance on cortex-a8. Some understanding were listed as follow, if there is any error, please correct me.
1. If a word (0x55aa for example)is written to a memory space(address A) which is write-back and write-allocate and a cache miss occurred, then [/size]
1) if there is no clean cache line, a certain cache line will be flush to main memory and then marked as clean, then a cache line will be allocated, and we name this cache line "cache line A" and assume the cache line size is 32bytes.
2) 32 bytes data in the destination memory will be filled to the cache line A .
3) 0x55aa will be written to cache line A and the cache line A will marked as "dirty"
2. If a word (0x55aa for example)is written to a memory space (address A) which is write-though and no-write-allocate and a cache miss occurred, then
1)0x55aa is write to the main memory directly.
2)There is no "copy" of (address A) in the cache.
3) If the address A was read, 32 bytes data will filled into the cache. If there is not clean cache, a certain cache line will be flush to main memory and then marked as clean.
Zhanguo Li
over 13 years ago
Note: This was originally posted on 22nd November 2011 at
-> [Jerry]So, if there 's no clean line in the cache, how ARM processors decide which line should be cleaned?
-> if clean lines and dirty lines both exist in the cache, how ARM processors decide which line should be cleaned?
-> Where I can get the doc about this?
"selects which line to replace first" means processor first select the line to replace with a pre-defined strategy, and then clean(flush+invalidate) the selected line if it's dirty.
RR(bit 14) of System Control Register (SCTLR) of ARMv7 TRM describes that:
0 - Normal replacement strategy, for example, random replacement
1 - Predictable strategy, for example, round-robin replacement.
Cancel
Vote up
0
Vote down
Cancel
Zhanguo Li
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
