Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Question about prioritized ARM interrupt
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Yang Fang
over 13 years ago
Note: This was originally posted on 3rd October 2011 at
http://forums.arm.com
One simple question but I did not find a clear answer. In the prioritized ARM interrupt, low and same priority interrupt will be masked out, so only higher priority interrupt can stop current interrupt. But will the lower interrupt flags also blocked? So another way to ask the question is whether lower interrupt will be ignored or there is a queue which will execute lower priority interrupt after current interrupt is serviced? Thank you.
Yang Fang
over 13 years ago
Note: This was originally posted on 5th October 2011 at
Thank you very much, folks.
Cancel
Vote up
0
Vote down
Cancel
Vaibhav Malik
over 13 years ago
Eric,
In case you are wondering around the software changing priority of the interrupt at run time before processor acknowledges the interrupt, then it is captured under spurious interrupt category (though it is unlikely from your question but just thought to share it)
Vaibhav
Cancel
Vote up
0
Vote down
Cancel
Vaibhav Malik
over 13 years ago
Eric,
There is another concept of interrupt nesting or preemption where the concept is signaling of higher priority pending interrupts to a target processor before an active interrupt completes. When this occurs, the initial active interrupt is said to have been preempted where the processor must save the context and later restore the same while resuming.
Vaibhav
Cancel
Vote up
0
Vote down
Cancel
Alban Rampon
over 13 years ago
Hi Eric,
I'm afraid that would be depending on the type of interrupt/archi.
I would recommend the
ARM Generic Interrupt Controller - ARM IHI 0048B (PDF)
spec document.
Then, looking at page 16 and the
Interrupt States
and
Types
, you can first distinguish
edge
or
level senstive
interrupts. They would be handled differently...
I'm not sure about "blocked" word meaning and would advise you to look for "pending" keyword in that document.
Kindly,
Alban.
PS: Thanks Luke
Cancel
Vote up
0
Vote down
Cancel
