Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
AXI transaction when ldm/stm instruction used on cortex-a9
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Jerry Fan
over 13 years ago
Note: This was originally posted on 15th September 2011 at
http://forums.arm.com
HI, ARM experts
I used ldm/stm instruction to copy(read-write) memory with caches disabled. The code is listed as:
int memcpy_8_regs(uint32_t * dst, uint32_t * src, uint32_t len)
asm volatile ("stmfd sp!, {r3-r10}\n");
while(len){
asm volatile ("ldmia r1!, {r3-r10}\n");
asm volatile ("stmia r0!, {r3-r10}\n");
len -= 32;
asm volatile ("ldmfd sp!, {r3-r10}\n");
return 0;
[font="Arial"]The code was run in a simulation enviroment and the operation of arm core can be observed.
The arm core issued a axi transaction with 16(bits) * 4(length) for write access, while a 32(bits) * 8(length) transaction for read access. It is kind of werid. Why not a 32(bits) * 8(length) transaction can be issued to get a maximum throughput? The limitation is because of the cortex-a9 arch?
BR
Jerry
[/font]
Marcus Harnisch
over 13 years ago
Note: This was originally posted on 19th September 2011 at
The MMU and caches are both disabled.
OK, so there can't be any memory access optimization. All memory is treated as strongly ordered (sort of). This means that all accesses to load registers must be 32bit accesses. According to section
8.1.2
in the Cortex-A9 TRM, 32bit write transactions can only come in bursts of lengths 1 or 2. For reading, bursts lengths of up to 16 beats are supported. That explains the observed behavior.
Kindly
Marcus
Cancel
Vote up
0
Vote down
Cancel
Marcus Harnisch
over 13 years ago
8.1.2
Kindly
Marcus
Cancel
Vote up
0
Vote down
Cancel
