Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
How to capture process id and multi-thread for application from ARM hardware
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
thiet pv
over 13 years ago
Note: This was originally posted on 5th September 2011 at
http://forums.arm.com
Dear all,
I am make a simulator for ARM (Cortex-a9). I want to capture process id and multi-thread for applications run on Linux kernel by this simulator, but I don't have good idea to capture it. I thought about CP15.c13 (Context PID register) of ARM but it seems not true for PID from kernel. I also think that Arm hardware will manage PID by stack and capture stack pointer will help to capture PID and multi-thread, but it is very difficult for me to understand about it. Please help me to find a solution to capture them.
Thanks and best regard,
thiet pv
over 13 years ago
Note: This was originally posted on 6th September 2011 at
Thanks for your reply,
I learn about contex register of ARM refer
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ddi0344c/Bgbeegaf.html
I think it can help to specify PID of each application. I see that the value of this register is not the same with PID in the linux kernel, but I don't know why?
Do you think that it can help to specify PID?
Cancel
Vote up
0
Vote down
Cancel
thiet pv
over 13 years ago
Thanks for your answer.
I also think the same you. The value contex id and pid in kernel is different. But I don't understand the mean of that register. Can you say the purpose of contex id register?
I learn and I have idea to specify process and multi-thread for applications by capture stack pointer, because each process will be contained on 8KB stack so if we capture stack pointer for each functions of application we can specify the and multi-thread for an application by hardware.
Do you think? please send me your comments.
Cancel
Vote up
0
Vote down
Cancel
Konrad Anton
over 13 years ago
You will probably have to interpret the Linux kernel's data structures (task queue etc) in RAM. As Linux is a very portable kernel, I doubt that the ARM port uses ARM specialty registers to store PIDs when most other processor architectures have no such register.
Cancel
Vote up
0
Vote down
Cancel
Peter Harris
over 13 years ago
This register is only loosely related to PID, and the mapping between PID and the value in this register is not a 1:1 mapping and time variant.
As the previous poster said, PID is a software construct managed by the kernel, and not something which exists in the hardware directly.
Iso
Cancel
Vote up
0
Vote down
Cancel
