Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
A basic question about data bus transfer
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Jerry Feng
over 13 years ago
Note: This was originally posted on 29th August 2011 at
http://forums.arm.com
In AMBA AHB spec2.0 or AHB lite,
for the data bus transfer with byte, there is a table (Active byte lanes for a 32-bit little-endian data bus) as shown in the attachment.
I am kind of confused with it.
1.
For byte transmission, I thought it was fine by just putting the byte data on data[7:0], why do we need different lanes?
2.
For the address offset, where does it come from?
In another words, how can I know which lane is active?
I googled but could not find some answers, it seemed that everyone knew how to deal with it except me.
Can someone give me some advice on those questions?
Thank you very much.
Jerry Feng
over 13 years ago
Is the question too simple or other else?
Can anyone tell me why I need to put byte in different lanes if I only need to transfer byte by byte?
Cancel
Vote up
0
Vote down
Cancel
Jerry Feng
over 13 years ago
Note: This was originally posted on 3rd September 2011 at
I got it.
The low bits of HWADDR is used to identify offset.
Then, if I want to transfer 8 bits in 32 bits bus in write mode, it will change its lane from time to time.
However, I thought it is not a good idea to do this.
Cancel
Vote up
0
Vote down
Cancel
Colin Campbell
over 13 years ago
Note: This was originally posted on 5th September 2011 at
Why not ?
Cancel
Vote up
0
Vote down
Cancel
Colin Campbell
over 13 years ago
Note: This was originally posted on 30th August 2011 at
The AHB (or AHB-lite) HADDR bus states the address of the required transfer. If this transfer is a byte transfer the HADDR value will include the "address offset" that tells you which byte lane is being used. So tables 3-6 and 3-7 in the spec show you the active byte lane(s) for various width transfers for various LSB combinations of HADDR (the offsets).
You cannot just attach an 8-bit device to D[7:0] only, it would need a MUX to select the relevant byte of the HWDATA bus, but for reads you could drive all bytes of the HRDATA bus with the same 8-bit read data value, and the AHB master will sample the byte from the correct byte lane it receives.
JD
Cancel
Vote up
0
Vote down
Cancel
