Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
NEON vs Intel SSE - equivalence of certain operations
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Marius Cetateanu
over 13 years ago
Note: This was originally posted on 26th August 2011 at
http://forums.arm.com
I'm having some trouble figuring out the NEON equivalence of a couple of Intel SSE operations.
It seems that NEON is not capable to handle an entire Q register at once(128 bit value data type; haven't found anything in
the arm_neon header or in the reference
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0348c/Badcdfad.html
What I want to do is the following:
// Intel SSE
// shift the entire 128 bit value with 2 bytes to the right; this is done without sign extension
// by shifting in zeros
__m128i val = _mm_srli_si128(d, 2);
// insert the least significant 16 bits of "some_16_bit_val"(the whole thing in this case)
// into the selected 16 bit integer of vector "val"(the 16 bit element with index 7 in this case)
val = _mm_insert_epi16(val, some_16_bit_val, 7);
I've looked at the shifting operations provided by NEON but could not find an equivalent way of
doing the above(I don't have much experience with NEON). Is it possible to do the above(I guess it is I just don't know how)?
Any pointers greatly appreciated.
Marius Cetateanu
over 13 years ago
You have
VEXT instruction.
This is not exactly the same thing, but that could do the job.
Already implemented it that way. I was wondering if there was something on the lines of how Intel does it.
Cancel
Vote up
0
Vote down
Cancel
Etienne SOBOLE
over 13 years ago
You have
VEXT instruction.
Cancel
Vote up
0
Vote down
Cancel
Shervin Emami
over 13 years ago
Note: This was originally posted on 27th August 2011 at
I have also wondered what is the best way to do this, since it is a very useful feature in many SIMD algorithms!
Cancel
Vote up
0
Vote down
Cancel
