Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Cortex-R4F : need explanations about some PMU events
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Christophe Beausoleil
over 13 years ago
Note: This was originally posted on 29th July 2011 at
http://forums.arm.com
I am using a Cortex-R4F (TMS570), and I used PMU to count the number of "Instruction architecturally executed" and "Dual-issued pair of instructions architecturally executed" (§6.1 of DDI0363E) in order to benchmark that component, and I get a strange result : I built a test code with 4096 instructions (in fact, a little bit more before and after the PMU is started/stopped), and I obtained :
- in ARM mode :
3083
2048 Dual-issued pair of instructions architecturally executed
- in Thumb mode :
4015
Please, could someone explain why the number of Instruction architecturally executed is not the same in both modes ?
And more important for me : how can I count the real number of instructions of any code ?
Thanks a lot
Best regards
Christophe
over 13 years ago
Note: This was originally posted on 20th February 2012 at
Hi all,
Does someone have an idea ? I really can not figure out why the PMU count is wrong...
Thanks a lot
Best regards
Christophe
Cancel
Vote up
0
Vote down
Cancel
over 13 years ago
Note: This was originally posted on 22nd February 2012 at
Thanks for your answer. I am sorry, I realize I was indistinct...
Of course, my test code is written in assembler :
movs r0, #1
nop
movs r1, #2
nop
movs r2, #3
nop
preceded with a strict directive for compiling in ARM or Thumb mode.
Best regards
Christophe
Cancel
Vote up
0
Vote down
Cancel
Martin Weidmann
over 13 years ago
You said that it should be 4096, how do you know this? What are you writing the code in? C will typically compile to more Thumb instructions than ARM instructions*, so what you've seen isn't necessarily wrong.
* There are cases where ARM instructions are more flexible than Thumb instructions. So the compiler can use one ARM instr or two Thumb instrs. This is less common with Thumb-2, but there are still some instances.
Cancel
Vote up
0
Vote down
Cancel
