Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
What to do upon detection of Error
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Muhammad Ahsan
over 13 years ago
Note: This was originally posted on 29th July 2011 at
http://forums.arm.com
I have implemented a couple of tests for Cortex-M3. These tests include calculation of CRC checksum over selected flash area, verification of Clock using Clock Supervisor and verification of occurance of Interrupts. the tests are working perfectly but I am not sure what to do, in case CRC checksum is wrong, or any of the other mentioned tests do not meet the desired results.
One option is to implement endless loop, waiting for watchdog to hit, is it meaningful? any other ideas would be highly appreciated.
All these tests are part of self test library that has to be integrated with the end user application. Is it make sense to leave it to the user to define whatever he thinks suitable in case of failure of component?
Looking for some quick response!
Regards,
Mahesh
over 13 years ago
Note: This was originally posted on 24th August 2011 at
I concur with ttfn , dependent on the type of verification test you could decide to either proceed with the next step or revalidate that test. Its entirely a system level decision. Perhaps if you had more specifics then we could provide better definitions for what your tests are really checking for?
Cancel
Vote up
0
Vote down
Cancel
Martin Weidmann
over 13 years ago
Note: This was originally posted on 2nd August 2011 at
There isn't really a set answer. The question you should ask yourself is what would a failure mean, and what would be must useful/safest to do.
For example, a CRC check might imply memory corruption. Memory corruption would mean you could not rely on code executing correctly. Therefore it might be best not to even attempt running it. What would be helpful? Error code? Error light? Error buzz?
Cancel
Vote up
0
Vote down
Cancel
